Interior \  fiberglass
fiberglass
Interior Q & A
views 293
replies 5
following 5
nvrhapy   +1y
i built a fiberglass center console last weekend, well half of the console hardened and half didn't what should i do, i used probly 4 different batches of fiberglass and i was just eying up the amount of hardner i put in there.the other thing is its pretty cold i just went out there and turned my heater on to see if that will help to harnen it.if that doesn't work can i put more resin over it with more hardner
klrbzcrtoys   +1y
put some hardener in a spray bottle and mist the unhardened area and more heat will help. if that doesnt work put another coat of resin with alot of hardener over it and more heat
lowdowndirtydawg   +1y
Use a heat gun and heat the area. More hardner and resin might cause it to become brittle and ruin it. The longer it takes to dry the stronger it will be.
mooneyes1   +1y
if it hasnt cured by now it never will
dubDyme   +1y
ive ran into this quite a few times, this is what i recommend. put a little fiberglass mat on it...the stranded, not the woven...this way itll pull all apart, then go over with a properly mixed batch and youll be good to go. 100% positive of this!
nvrhapy   +1y
ok guys will do thanks for the info!!!!!
