Ford Trucks \  removing interior a/c unit
Ford Trucks Make Specific
views 318
replies 16
following 8
FordMXRacer36   +1y
I am trying to remove the a/c unit what is inside the cab but its being a b*tch. can someone help before pull out the sledge and go to town.
bodydropped85   +1y
u gota pull the dash.
FordMXRacer36   +1y
im way past that....all i have left from the interior is the a/c unit
bodydropped85   +1y
take the bolts out it should come out...
FordMXRacer36   +1y
anyone other helpful ideas...
dssur   +1y
did you disconnect the ac lines that connect to it in the engine compartment? Big aluminum hard lines with giant aluminum fittings.
bodydropped85   +1y
yea i was sayin that assumin you have alrady took the box off of the front of the firewall, its gota come off first. there are bolts for it behind it.
FordMXRacer36   +1y
yea the hardlines under the hood are disconected. I just cant seem to find what else is holding the a/c unit in place. It cant be much.. it moves since I took about 8 bolts that I could find out and now I can not find anything else and still can not get it out.
dssur   +1y
there is a water drain line, did you remove that?
mmautoworks   +1y
HEY MAN THERE IS ABOUT THREE OR FOUR ON THE FIREWALL SOME ARE BEHIND THE ENGINE AND ARE A PAIN IN THE ASS TO GET TO BUT I WORK AT THE FORD DEALER AND DO THEM ALL THE TIME ONCE YOU GET THEM LOOSE SOMETIMES YOU HAVE TO GIVE IT A GOOD JERK TO GET IT LOOSE
