isuzu spindles
isuzu spindles
treyonelow94
does anybody know if isuzu truck lowering spindles will bolt up to a two wheel drive amigo any help would be great
ddranged
i don't know for sure but they should i thought they were on the same style chassis. you could just call the parts store and see if the ball joints and bearings and brakes are the same part number and size. if so they should swap no problem. if not you could just get the brakes and arms off a pick up and make it work.
cuzican's avatar
cuzican
The Amigo is on a 4wd chassis even in 2wd form. You would need: new brakes, rotors, bearings, and hubs. I have checked one of the balljoints is the same, I believe it was the lower but, I could be wrong. The other is the same part number. You may be able to bolt the other balljoint to your arm but, I'm not sure. Also I have not checked on the tierods to see if they are the same. This might not help any but, atleast now you know that one of the two balljoints will work, LOL.
sponge splawn's avatar
sponge splawn
I didnt realy dig into my 2wd Amigo when I had it, but I beleive it is just like my Rodeo. They both sit on a 4wd frames with dummy hubs. The suspension drops down below the frame greatly with a lower A-arm instead of a single lower arm with tie rod ends, and the spindles are to short and not interchangable at all. This is why I put an entire 2wd front clip under my Rodeo.
cuzican's avatar
cuzican
^^^^^Exact same as the front of a Rodeo, so go with what he said.
treyonelow94
thanks alot for the imput it was a ton of help and saved me a lot of headache we got the truck to lay on the factory frame for now on escalade rims not the greatest but def getting there and now i know what to do to get it all the way down thanks
Related Discussions in Isuzu
