Air Ride Suspensions \  isuzu spindles
isuzu spindles
Air Ride Suspensions Q & A
views 299
replies 3
treyonelow94   +1y
does anybody know if drop spindles for the truck will bolt on a 94 two wheel drive amigo any help would be great thanks....
laidiscrewu   +1y
i think not the frontends are alot different,I was gonna take a truck front frame clip and put it on the amigo it would make everything alot easyer,that was intill i sold it,
shortrodeo   +1y
No they will not fit. The Amego/Rodeo even in a 2wheel drive all use the 4x4 chassie, which has different control arms and spindels then the 2wd Truck.
If you want to lay out your Amego. I suggest you get a Toyota front clip and stuff that in there. It will be alot easier to get the rims you want in the 5 lug and it will deff be alot easier to lay out.
shortrodeo   +1y
Here is your other forum where the isuzu guys went over the difference in frames and made suggestions on how to get an amego on the ground.
http://www.streetsourcemag.com/forum/forum.aspx?forum_id=44
