Audio/Video \  Need wiring help
Need wiring help
Audio/Video Q & A
views 153
replies 3
CHOSN1   +1y
My first time trying to wire a stereo up. its in a 2003 Chevy silverado and I'm installing a new Alpine cd player. From the diagram, I have installed speakers correctly. And I believe I have hooked up power and ground up correctly but still no power. I have DVOM the power and I do have power and I have run a test light to see if my ground was good and the light lit up. So I'm guessing ground is good. But when I turn cd on, i still get nothing. There is a couple wires i have questions about though. It is from the wiring harness. It is a red wire that says it is suspose to go to ignition and then an orange wire that says it's an "illumination" light. DO i need to hook these up and to what if I do. Also, from the truck wiring harness there is a smaller orange cable. I looked it up on alldatapro and it says its an data connection wire. what the hell is this? Thanks
LOWEST1   +1y
Yes you need to hook up the red ignition wire. The orange wire would just dim your deck when you dim the dash lights.
lowazzmaz   +1y
truck prolly does not have an ignition on wire behind the radio it was all data bus. what I used to do as an installer was run my own ignition from the main wiring harness from the ignition. It will be a pink wire, should be a 10 guage and will be grouped with other similar wires under the steering column. Just run you a wire from there fused of course and hook it to the red wire on the radio should do the trick, and you will be rockin'....
CHOSN1   +1y
I just got back from Best Buy to pick up a GM wiring harness. I show him the harness that I cut from the truck and he said all I have to do is connect that small orange wire, which he said was the ignition on, to the red ignition wire coming from cd player. So I get back to truck and connect the wires and still nothing. I had messed around with the ground wire so I will check that out in morning and see if that worked.
