98+ ranger flipped spindles
devilx avatar
devilx
i've heard something about flipping the spindles so they act as 2 inch dropped spindles.does anyone know anything about this? is it safe?
bodydropped85 avatar
bodydropped85
definatly not safe, as it pulls the rim into the control arm. and its flipping the lower ball joint.
devilx avatar
devilx
what makes it unsafe? so i ahve a good idea what you are talking about.i've heard like two different people talk about it.
bodydropped85
its the way the control arm is made. there isnt room for it.
dan48p avatar
dan48p
when you flip the balljoint on them things you actually turn it over? everyone on the yota board just mounts the lower balljoint on the top of the lca, thats how mine is done. they aren't ranger arms though.
i actually haven't seen the front end of a newer 2wd ranger. but i think i got about 3/4" from flipping the lower, and its just as safe as it was before.
still2low4urho avatar
still2low4urho
the guy who bagged my ranger put a 98 clip out of a ranger in a like 94 exploder. He cut the control off like 3 inches from the end and raised it like 2 inches. He gusseted it up and it looked good but he said he had to raise the rack and pinion to make everything work in theory. He said he wished he would have just stuck with the i beams....
bodydropped85
sadly your better off w/ the 98 up clip then ibeams, even tho both designs isnt teh best for airbags and big wheels. also the lower ball joint is PRESSED in not bolted.
msturg avatar
msturg
That's what's unsafe about ball joint flips, lol. Granted that's on the torsion bar setup, but the control arms would have to be cut similiarly. That's on 18's btw.
LOWEST1 avatar
LOWEST1
HOLY F***!!! That is scary, I dont even know why someone would think that was okay????
bodydropped85
thats the exact pic i was thinkin of mike.
