Dodge Trucks \  what to do
what to do
Dodge Trucks Make Specific
views 239
replies 6
following 5
nvrhapy   +1y
i'm having a hard time finding 18's that will tuck on my bagged 92 dakota what is the easiest and cheapest way to go about making this more of a possibility, what is everyone doing shortening everything, changing patterns? let me know what you guys think thanks
Central Customs   +1y
if the lugs are covered you can have the back of the rim cut down and new lug holed drilled
Sickota   +1y
what he said is all you can do without getting upper and lower arms.
draggindakota   +1y
Just swap your rotors, calipers, drums and axle shafts with ones from a pre-91. Instant 5x4.5 pattern.
Sickota   +1y
i had no idea the pre-91 were 5 lugs. Are there axles shorter to?
nvrhapy   +1y
draggindakota have you done this before or has anyone done this before??? seems interesting
RobbyDizzleonDubs   +1y
IDK about the axle shafts being shorter, but swap the rotors and calipers and drums. Y0u might need to redrill your axles shaft and have to 5X4.5mm
