Air Ride Suspensions \  Front bags?
Front bags?
Air Ride Suspensions Q & A
views 129
replies 6
scotto79   +1y
When I'm setting up to mount my front bags, do I measure the mount from the LCA and go with the full compression measurement or give it a half inch extra? This is with Slam re7's by the way.
creative concepts   +1y
no.. you weld in your lower bag mount.. jack up your suspension till your wheel/tire is higher then the frame.. measure up 3" from that and that is where the upper bag mount goes.. that way when laid out, you are fully compressed.
scotto79   +1y
its with CanDo arms, so its just a plate on the bottom. So I push my LCA all the way up and then go 3" from there, correct?
Fraynlame   +1y
I'd bolt the bag to the LCA with the upper bolted in, jack up the wheel all the way, compress the bag and tack it in.
strip it , gusset it, and weld her in.
But what do I know, I have I-beams haha.
sorry man, but compressing a slam bag by hand, let alone holding it all in place, isnt happening.. 3" is their number compressed.. actually its 2.9" till the bumpstop.. so you're good with 3.
scotto79   +1y
I was thinking the same thing about compressing them by hand, so I'll just go with a 3" piece of tubing to use. It makes sure the mounts stay squared to the LCA as well I'm guessing.
