Body work and Paint \  smooth tailgate
smooth tailgate
Body work and Paint Q & A
views 152
replies 5
following 5
yasmany454ss   +1y
ok im going to shaved my tailgate the questions is whats th best filler and primer and should i do the body work over primer or bare metal? and by the inside i paint the filler plate? thanks
ricky@3rdshift   +1y
I would recomend Rage fillers, and some weld through primer on the tailgate where your welding in the filler. I would coat the inside of your filler and any bare metal that will be under it.
dragn168   +1y
any thing evercoat and deffinitly paint the back side so it doesnt rust
standardbyker88   +1y
im not sure if you have a removable panel on the inside of the gate (like toyotas), but if you do, i would recommend taking it off after you weld in the filler and then spray some rattle can rustoleum or something to keep anything from rusting. that would suck to have a rotted and shaved tailgate. good luck man. post pics.
yasmany454ss   +1y
ok but when i finish welding the filler and is all nice and smooth should i just do the bondy work over it or prime it first.also should i cut the lip were the handle sits so my filler is edge to edge or should i just put it over it
Captain Quicktoy   +1y
Weld, sand, fill, sand, fill again, sand, prime, sand, prime again, scuff sand, paint, clear, wet sand, buff
theres your steps
