Loctite?
Loctite?
capcomfan19
yeah im trying to do my fbss setup in loctite. im tired of teflon. i ordered 4 of those little bottles from sd. when i was experimenting i put a bead of loctite all the way around the fitting. well 1 bottle did both sides of four fitting or 8 sets of thread... did i use too much? at this rate i cant even do 1/2 my setup thanks....
TwistedMinis's avatar
TwistedMinis
Just put a little drop on the threads. It will spread itself around. A little bit of loc tite, goes a long, long way.
dirkbelt's avatar
dirkbelt
is it better thatn teflon???can u use both
9
92yota
i got a huge bottle of loctite on ebay really cheap, and its the same kind that SD sells, if you need more of it. Personally, i've tried teflon tape and paste in the past and always had leaks, though it seems to work well for other people. ever since i used the loctite i haven't had any leaks at all. it only takes a little like seth said, just don't put any on the first couple of threads so it doesn't get into your system.
time1's avatar
time1
Edited: 4/3/2007 2:22:18 PM by TiMe_1
This shit OWNS everything.
I have put fittings on my old truck as tight as i could get them by HAND and dont have any leaks. It gets messy but its worth it!
LOWEST1's avatar
LOWEST1
Originally posted by TwistedMinis
Just put a little drop on the threads. It will spread itself around. A little bit of loc tite, goes a long, long way.^^^I agree, if you use to much it just oozes out and you waste it. It is better than teflon any day. I personally bought a larger bottle I think it is around 7 oz.
bodydropped85's avatar
bodydropped85
were do you find this stuff at? even the name sounds cool lol
time1's avatar
time1
Out here you can get it from Lowes and Home Depot.
bodydropped85
sweet. ill have to check on taht stuff.
s10
last post by baha +1y
