Left front corner deflating faster than other bags
lowerlevelz@msn.com's avatar
lowerlevelz's avatar
lowerlevelz
Edited: 4/3/2007 2:55:01 PM by lowerlevelz
Wondering why my left front corner bag is deflating faster than the others?? I have a 2 switch setup. One for front and one for back. Back valves are seperate from front vavles. I removed one of my digital senders in the front due to leaking. Could that be the problem or something else i'm not sure? i figured air travels equally through all the lines no matter what. Ive checked the front bag and it's not getting hung up on anything. It inflates fully and sits level, and layd out sits level it's at about rolling height were it's noticably unlevel on the drivers side. Any input would be well valued!
ShakinPlates's avatar
ShakinPlates
SPRAY SOAPY WATER ON THE PORT OFF YOUR TANK THAT GOES TO THAT BAG AND I BET YOU WILL GET BUBBLES
layedoutdreams
Edited: 4/3/2007 3:33:39 PM by LayedOutDreams
It's probably not level because it's a two way setup. Air is free to move back and forth between the front bags, so if there's more weight or something on one side, that side is gonna be lower. It even happens with FBSS too, cause when I have a fat ass friend sitting in the passenger seat, my front right doesn't go as high as with only me in the truck.
cantlooswit22s's avatar
cantlooswit22s
sometimes that happens with a f/b setup. you have the weight of the driver and the gas tank on that side.so youll have more weight on the left than you will the right...ooorr,if its been doin this since the day it got bagged,the mounts might not be the in the same location or cups not the same size....
fatboysS1O's avatar
fatboysS1O
what he said, and i do believe ive been told at one point that if your driving a s10 that they tend to lean that way anyway. i believe they called it the s10 lean. like cantloos said because of the gas tank etc.
V
VtecCrx
Or the lines going to the front bags are different lengths. That could cause it also.
