subs to fac. systems
dzctoy@aol.com's avatar
lotoy86's avatar
lotoy86
where can i go to get a factory wire diagram for a 2004 sebring? i want to keep the factory radio cuz its my girl drives it. thanks guys
corey0814's avatar
corey0814
most haynes manuals have schematics in the back, even most chilton's too
CHOSN1's avatar
CHOSN1
what kind of engine you have? i can look it up for you
03on22s's avatar
03on22s
Are the speakers in the back deck on that car? If so just tap in under the deck in the trunk.
ShakinPlates's avatar
ShakinPlates
GET A HIGH TO LOW LEVEL ADAPTOR
lotoy86's avatar
lotoy86
cool thanks i have never really delt with this stuff much before i would just throw in an aftermarket radio and go from there but its under warrenty and ill just wait untill it goes out to do anything
maniacalmini's avatar
maniacalmini
Radio 12v orange/black to red/white + radio harness
Radio Ground (chassis)
Radio Ignition white/black + radio harness
Radio Illumination green/white + radio harness
Factory Amp Turn-on N/A
Power Antenna N/A
LF Speaker +/- white/blue - black/blue +,- radio harness or amp under pass seat
RF Speaker +/- white/red - black/red +,- radio harness or amp under pass seat
LR Speaker +/- yellow/blue - gray/blue +,- radio harness or amp under pass seat
RR Speaker +/- yellow/red - gray/red +,- radio harness or amp under pass seat
lotoy86's avatar
lotoy86
man thank you so much
granth
changing a radio wont mess up warranty...and if they say it does, fight it. the ONLY thing they could put the radio at fault for, is if something in the audio system/wiring went faulty. like with engines, if you put on an intake and you sling a rod, they can't just put the cause of that on your intake. they have to prove what caused it. It's not worth the legal fees for them to fight it, so they usually just let it go and replace the part (knowing thats what is supposed to happen anyways)
