dssur
you will never lay full frame with the leaf spring mounts still in, they are lower than the frame. You can drag almost through your leafs and not lay out, ask me how I know?
Otherwise the most you can do is lay perch, and if you arent laying perch you need to dearch the leafs. Too much block and it will hang lower than your tire, cant do that relaibly anyway, stacking 5 inches of block is bad. Dearching is done by spring shops, try a company that deals with semi trucks, there is usually one in every town. Costs about 75 bucks here.
