i been running 3/8 lines and valves but i want to speed the dumps up. i was thinkin about converting the lines and fittings to 1/2 inch and using the same 3/8 valves but will it dump faster with a 1/2 inch valve?
the volume will only effect the lift right? cause i know the orfice on 3/8 and 1/2 inch valves are bigger than the actual inside diamiter of the 1/2 inch line is that right
Yeah, mine dumps damn fast and the valves are about 2' away. I have alot of 3/8" NPT to 1/2"OD hose fittings for sale if you wanna convert to 1/2" lines.
