Another Pinion Angle ???
texmextukin@yahoo.com's avatar
Texmextukin's avatar
Texmextukin
Edited: 4/9/2007 4:43:05 PM by Texmextukin
Whats up guys? Im building a 3-link right now for my s-dime. And im wondering if i use some of the axle brackets like the lift bars use on the SD 5-link, will it keep my pinion angle change to a minimum?
http://www.suicidedoors.com/showfullimage.php?type=products&image=LiftBarAxleBracketKit.jpg&title=Lift%20Bar%20Axle%20Bracket%20Kit
dssur's avatar
dssur
no, that will make pinion change worse. If you use those shackles like on the axle side of the lift bars, they will always be seeking equilirium of forces and will flop around.
The reason they use those on the 5 link is because the rear lift bars have a different arc of operation than the 3 forward (rigidly mounted I might add) bars and will need the adjustments provided by the shackles.
The locating bars need to be rigid. The lift bars can be mounted with shackles if the locating bars are rigid, but not otherwise.
Texmextukin
Thanks Bro. I just wasn't sure about it, but now i know what you mean. Thanks alot man.
s10
last post by baha +1y
