Ranger 302 radiator
Ranger 302 radiator
broadband
What is everyone running for a radiator in their rangers after they did the 302 swap? Is there a stock 4 core that will work? That is the last piece of my ranger puzzle cause i want to drive it this summer.
bodydropped85's avatar
bodydropped85
get a 3 core radiator from a 4.0 ranger. explorers are bigger, you could use one from a v8 explorer IMO.
dan48p's avatar
dan48p
from the reasearch i've done on rps the one to use is the 4.0 radiator with the "extra cooling package" supposedly this bolts up to the stock radiator mounts. however, if clearance is an issue you can get a swap radiator that tucks inside of the support rather than behind it.
http://www.rangerpowersports.com/tech/?p=59
Ratical's avatar
Ratical
I'm using a be cool aluminum.
dwnlowx
we used a ford explorer v8 radiator thats what im using in my sport
dan48p's avatar
dan48p
i was looking at explorer radiators on car-part and was wondering if the v8 radiator for a 97 w/ an automatic tranny will fit the same in a 92 ranger.
what exactly are you looking for in the explorer radiators to get them to fit?
are there differences in the physical dimensions of the core supports between the different trucks?
bodydropped85
youll have to make it fit in your ranger, the core supports are close, but the explorer radiator is a lil bit bigger.
Droptout2's avatar
Droptout2
i have a griffin radiator in mine, but had to cut some of the core support to fit it. its a real tight fit in there. but like james said, a 3 core from a 4.0 should work pretty nice as well. good luck!
