pcv valve 22re 93
tuckinlugs05@yahoo.com's avatar
pcv valve 22re 93
tuckinlugs06's avatar
tuckinlugs06
ok need help removing the valve i try and pull it out and this mother wont move ...is there a trick to remove it
dragontoy22r's avatar
dragontoy22r
Break it if you have to. A grommet goes into the valve cover, then the PCV valve. If you can carefully cut away some of the grommet at the base, then it should come out fairly easily. Or try some penetrant. The foaming kind works best.
madmatt's avatar
madmatt
it will come out. I thought it was permanently sealed in there or something, but some channelocks and a little back and forth motion and it comes out.
dragontoy22r
Are you suggesting he do pelvic thrusts while holding his PCV valve? LOL! J/K
framescr8pintoy's avatar
framescr8pintoy
mine wouldnt come out so i ended up cutting the grommet and then it pulled out. just buy a new one theyre cheap.
9
92yota
this may be a stupid question, but what is a pcv valve and why are you removing it?
TwistedMinis's avatar
TwistedMinis
Its smog equipment. His might be bad. I've always been told if you shape them and they make noise they're useable, but if they don't make noise they're bad. Kinda bassackwards, but supposedly thats it. If not, mine is broken.
tukn18saccord's avatar
tukn18saccord
it will come out just keep working with it
dragontoy22r
Positive Crankcase Ventilation Valve. Basically a check valve for your emissions. It allows excess fumes to be filtered through your air intake system.
framescr8pintoy
i took mine out to have my cover powdercoated.
