i don't know
spazkid8807@yahoo.com's avatar
i don't know
atomants95's avatar
atomants95
i drove my s10 around my block after putting it back together and it ran fine for about 10 minutes then it started sputtering. i put it in park then back in drive and it ran fine. i took it back home and parked it for the night. the next day i went to go start it, it wouldn't start without me pushing the gas pedal down. and it won't run at idle. i don't know what is wrong. i have a 4.3 if anybody can help i am asking for some advice
my1994s10's avatar
my1994s10
We got another thread named "truck dies when put in gear" http://streetsourcemag.com/forum/topic.aspx?method=reply&topic_id=89511&forum_id=19&forum_title=&M=False&S=True
Do you have the CPI 4.3 because I just bought a Jimmy and its givin me the same issues? Go check out that forum cuz some people give some suggestions.
atomants95's avatar
atomants95
i found out today that it was my temperature sensor. thanks anyway
my1994s10's avatar
my1994s10
Well for some reason I'm having the same issue even after replacing the temperature sensor. Does anyone else have any ideas? I'd greatly appreciate them cuz I just got my new tires mounted and I'm ready to actually drive it!!!!!!!!
BggdNBdyDrppdJunk's avatar
BggdNBdyDrppdJunk
is it carbureted?
my1994s10's avatar
my1994s10
fuel injected
BggdNBdyDrppdJunk
it wont start at all? or does it crank and not start?
my1994s10's avatar
my1994s10
Itll crank and wont start unless you give it some gas. It will slowly idle and sometimes die but will stay running if you keep your foot on the gas. So I've only drove it twice like this and I have to put it in neutral at the stop lights/sign so i can keep a little gas goin in. I do appreciate your concern eddie, hopefully youll be able to point me in the right direction. Thanks
BggdNBdyDrppdJunk
does it sound funny when you hit the gas and when it idles, kind of an off rythm sputter? your timing may be off, thats the first thing i would check since its the easiest
pewter2000
this is the exact same thing my asro does 4.3 tbi,had a couple mechanics look at it still nothing? it seems to run better when its colder out???
