93 f150 sud frame swap
alldragcivic@yahoo.com's avatar
laidoutcourier's avatar
laidoutcourier
i was just seeing if anyone had some suggestions on a front susp. swap to get rid of the i beams
i was told by a guy that a 80s arowstar would work and be able to hold up to the waight i am waving my options thanks
trenth48
mustang II
thebagged1
yea deffinatly mustang 2... way more parts and easier... even better than 97+ f150 suspension
bodydropped85's avatar
bodydropped85
Edited: 4/16/2007 3:52:43 PM by bagged85
if ur lookin for cheep, fullsize chevy. should be the same lug pattern and u get lovly contorl arms and a jillion aftermarket parts for it. and who ever told you an aerostar would work has never looked at there crappy ass suspension lol. if you are lookin for just static ride height, then a MII will work but it mite break the bank. MIIs are known for binding out on big wheels w/ out alot of work.also parst are readily availbe at parts stores for a FSC clip(track width should be around the same, if not narrower)
LOWEST1's avatar
LOWEST1
Full sive Fords are a 5x5.5 Arent they?? Chevys are a 5x5
bbb's avatar
bbb
Yup. They are not the same.But you can find rims with both patterns.
bodydropped85
huh coulda swore they were teh same, maybe it was dodge and ford that is the same idk.
dan48p's avatar
dan48p
just to chime in the mustang 2 can be had for 900 bucks from speedway i believe it is. this is with everything but the engine crossmember.new brakes tubular arms rack and everything else
MF
Master Fabber
On the 96 bronco I did, I used the mustang 2. I was able to build 2 " longer a-arms and get 2" longer tie rod ends. This allowed a good amount of travel over stock. The lug pattern is small five on 4.5 though. Your stock pattern is 5 on 5.5. I matched a 9" rear axle to the front. Hope this helps/ Also it layed door on a 295/40/22 with no room to spare. The tire just missed the hood and just cleared lifted.
///RA TROY's avatar
///RA TROY
doing a mustang II right now on 20s not problem probably could do 22s but i did make all my own control arm mounts
