Fuel gauge/sending unit ?
ramsfergus@hotmail.com's avatar
ramsey's avatar
ramsey
Does anyone know if a GM style sending unit can be made to work with my factory Dakota fuel gauge. I have a fuel cell that I would like to use, it came with a GM compatible sending unit, and I would really like to use my factory gauge.
cantlooswit22s's avatar
cantlooswit22s
not to sure.if the dakotas are the same ohm reading as the fullsize dodge,they might not cuz gm and dodge readings are WAY different. you might be able to get them to work with diodes or something,but id just change the sending unit to match honestly.
ramslam1998
why dont you use the factory sending unit and pump and just shorten the plumbing?
Brill's avatar
Brill
Would cutting / extending the fuel tank wires mess up the ohm rating or whatever.. I'm no electrician by any means..
I extended the wires for the fuel tank on My S10.. and my fuel guage works half ass.. hald the time..
ScojoDak
Shortening/lengthening wires (within reason) will not affect resistence.
Dusty, sounds like you have a bad connection.
cantlooswit22s
as long as you dont extend them 20'...lol. but wat he said^^^^
corey0814's avatar
corey0814
GM sending units read 0 ohms empty & 90 ohms full, so you'll just have to hook up your meter, move your float (or slide up the ring or however yours works) & see what your ohms are at empty & full & if they match, you're fine; just splice it in. also they're right that if it's reasonable, the resistance won't change too much.
