Replacement diaphram for older Parker Valves
Jfo
I have some older Parker Valves and am having a problwm with them leaking.I ttok the diaphram out of the valves that was leaking up and moved it to the dump and now the dump valve leaks down so I know that the diaphram is the problem.Does anyone know where to get replacement parts for Parker valves.I've looked around and can't seem to find anywhere to order parts.
Thanks
Hc Daytona Dragger's avatar
Hc Daytona Dragger
I have those valves to... Try Grainger or Parker themselves, good luck though if they are the "Barkin" parkers, like mine they havent been made in a long time you might run into some issuses
Jfo
I saw on the valve it said Skinner if that is a certain type of Parker valve...by the way I took the diaphram out and cleaned it with warm water and soap and put it back in and still it leaks.
s10
last post by baha +1y
