Chevy/GMC Trucks \  back half question
back half question
views 107
replies 4
following 5
soontobelayed   +1y
so i am building a notch and rails for my 99 gmc and i got them all tacked in and leveled and everything was perfect but i started welding it in and i put jackstands under it to keep it level but when i pulled them out and one side sunk about a quarter of an inch. the main reason for doing this was so my 22's will clear and so i can hang a cell in the back i think besides shimming the bed and tank that is the only thing it will affect but i still want it right any ideas on how i could do it with out cutting it completely out
Iownissan   +1y
the heat from welding it is probably the cause of it moving/pulling. since a 1/4" isn't a lot, you could probably just leave it and shim it like you said.
splitdecision   +1y
If you or somebody you know can get you in a bodyshop with floor tie downs you can tie it down and then jack the low rail back up level with the other one.
keele   +1y
I'd say you would probably be fine how it is man. When I did the hardbody and got everything welded up i was bout the width of a washer from being level anymore. I just adjusted the slack out with a shim when I mounted the bed.
BADHABITMAN   +1y
depending on where the tweak started you could cut the top and side welds with a sawzall then jack up the frame rail & re weld it, V it out first of course. This will allow the frame to go straight without tweaking the rest of the frame.
