Foreign Cars (honda, etc) \  drag plates
drag plates
views 174
replies 5
following 2
dropatbirth13   +1y
ok i have a 95 civic im put cans(air ride) on it has 14in rims so im going to lay hard were dose every one put there drag plates to stop messing up oilpan gas tank ect..
RedHJedi   +1y
Edited: 4/19/2007 7:14:55 AM by RedHJedi
If you're just bolting air cylinders into your factory shock towers, your oil pan is quite safe from dragging. (unless you're going to run some seriously small tires)
Dave
dropatbirth13   +1y
it got 185/40/14
RedHJedi   +1y
Well, those should be 9.9" diameter at the tread...mine are 205/40/17...and I'm at 11.7"
you might be close...
Dave
dropatbirth13   +1y
I plan to notch my shock towers in the front for my a arms and run 3 inch cylinders in the front with custome 1 1/2 inch drop spindles and for the rear 1 1/2 inch trailing arms with a canti-lever so yes it will most likely lay body. just trying to take of what is important the motor and the gas tank.
dropatbirth13   +1y
