Rattle when my truck starts
9
98underconstruction
so when my 91 gmc starts it has a little rattle, but only when it starts and it last for about 4 or 5 seconds, just wondering if anyone would know what causes this? thanks for any info
psicolow1
more then likely it is a lower end main bearing knock until oil press goes up.
psicolow1
gm was aware of this problem on these trucks and released redesigned rear main bearings.
psicolow1
as long as oil pressure is good i wouldnt worry about it. just take it easy on the eng until oil press is at normal level. hell i have a 97 with 194k on it and its been making the same noise since 100k.
9
98underconstruction
alrite, so how would i go about repairing this?
CDOG23
Also check torque converter bolts. Loose torque converter bolts and a cracked flywheel caused that condition on my 90.
9
98underconstruction
ok, i'll check it out, i was thinking possibly a flywheel problem, but i was just tryin to see what other problems it could be, thanks
