1991b2600i fuel injector help.
carolinasled
i have a leaky fuel injector. the first injector towards the front of the truck and i bought the o-ring kit for 1 fuel injector but the guys at napa couldnt tell me anything so i'm lookin for some help here.
i dont know what to do or where to get started or removing from engine to pull out or what?
any help. Ryan.
dssur's avatar
dssur
The injectors arent bolted in, they are sandwiched between the fuel rail and the manifold. So you unbolt the fuel rail and using even pressure pull it straight off the injectors. Then you can pull the individual injectors, either from the rail (if they stick in it, remember that they are just sadnwiched) or from the manifold (if they didnt stick in the rail. Should take about 30 minutes to do one.
dssur's avatar
dssur
Oh, pull them straight out or push them straight in.
And you should get more o ring kits because its cheap insurance to do all 4, top and bottom o ring.
carolinasled
thanks russ-d.
