Dog leg???...WTF?
11 following
lostcause@blomand.net's avatar
Dog leg???...WTF?
lost cause's avatar
lost cause
I just want to know how in the hell it works???? I'm putting cans on my hatchback and definetly want to be able to bust out the three wheel tuck....Somone at street beat told me all I need are "spool valves" WTF are those?? how are they different then normal valves?...do they suck the air out or somthing? How in the hell is it done Honda guys?
...........Thanks "Lost Cause"
Please post pics if you have them.....Thanks
HS
hybrid showoff
just run another fill and dump valve to the bottom of the cylinder and wire it up to a switch
BK2LIFE's avatar
BK2LIFE
yeah there is a whole at the bottom of the cylinder, attatch a line, blow air in it, and the tire will come off the ground. use whatever valve you want. ive used cheapo vlaves for it, as why waste money where you dont need to
RHMNISSAN
With cans all you need is air pressure. Lift the whole car to max lift, then dump the front corner. It should dogleg a little. If you want it to lift high you have to run a suck up valve to the back corner.
RHMNISSAN
fatboysS1O's avatar
fatboysS1O
yeah just run another dump and fill valve to the port in the bottom of your cylinder. air car up dump opposite front corner of car then the opposite back corner should dog leg a little, then hit your extra fill valve and it should suck the tire up.
fatboysS1O's avatar
fatboysS1O
thats how ive been told it works anyway!
lost cause's avatar
lost cause
Edited: 4/25/2007 2:14:29 PM by lost cause
Edited: 4/25/2007 2:12:56 PM by lost cause
Hell yeah,.....You guys made it sound extremly simple!Thanks.
The only thing that I'm not 100% about is, Are both valves always being used at the same time? Like, when one set of valves is filling up the clylinder, The other valve would have to dump (and vise-versa) to let the cylinder mover right?.........So what i'm getting at is,...Is there always pressure on both sides of the cylinder? and if so would it ride like shit? Thanks Guys!
Any one have any pics?....................."Lost Cause"
dragn168's avatar
dragn168
u have to dump the air out of the cylinder first before you try to suck it up so theres no resistance
