Ranger Pitman Arm Question
RangerOn18Cobras
We're body dropping my 96 on 20s with beams...the stock pitman arm is hitting....will an arm from a 4x4 work or what should we use?
mindlissmetalfab's avatar
mindlissmetalfab
As much as it sucks you have to bend the tie rod a little. Just heat up the rod a little and put a bit of a spacer between the arm and the tie rod and let the weight of the truck bend it.
I put off doing it for like 2 weeks on the one we did, but finally caved and did it. truck has had no issues with it.
There was a reason the dropped arm wont work. i looked into it to.
bodydropped85's avatar
bodydropped85
it digs into the ground thats y(4x4 one). yup u have to bend the tie rod a lil.
RangerOn18Cobras
thanks for your help!!
TRUKBLDR's avatar
TRUKBLDR
WHAT DOES THE TIEROD HIT ON
bodydropped85
the pitman arm, only ibeamers tho.
