weld thru primer
weld thru primer
yasmany454ss avatar
yasmany454ss
how you guys doing. today i shaved the stake pocket holes on my truck chevy dually...i spray the inside of the pockets with the primer and thee back side of the filler plate. i wited 30 mins before welding it .when i starting weldeing the filler plate shut that primer started to burn off i could smell it.... why is called weld thru primer then if is going to come right off.. help me with these b cuz i dont whant my filler to rust inside out
thanks guys
FreelandKustomz avatar
FreelandKustomz
weld through primer is a joke. i never mess with it.
slammedcivicsi avatar
slammedcivicsi
its because you can weld through it with no problems with penetration. Welding over a traditional primer, is no differnt that welding over paint. The weld through coating is only to give the backside of your weld corrosion protection. On the surface your painting, you will need to wipe off any weld through coating with some thinner. Weld though primer is basically just Zinc. So its not designed for adhesion. But the backside of your weld should be nice and protected.
-Brad
yasmany454ss avatar
yasmany454ss
i dont know how any paint or primer will hold to the welding heat...so on the case of my stake pockets how do i sela the back side so it wont rust if i cant get to it
yasmany454ss avatar
yasmany454ss
well after 30 mins it was not still dry
project94 avatar
project94
weld thru primer is mainly zinc, when it is heated by the weld it bonds with the metal which creates the corrosion protection kinda like the e coat that comes on factory panels...
GOT FLAKE avatar
GOT FLAKE
weld thru primer is mainly for when you weld body panels together its just to prevent moisture from gettin in the cracks and rusting
bgp1mpin avatar
bgp1mpin
you are only supposed to put one medium coat on the back side of the metal so it should dry almost immediately (like 2 minutes)but after you weld you are still supposed to recoat the back side with a self etch primer of some sort its just suppsed to help the metal that cant be recoated like a the backing panel or insert your welding to hope this helps
bodydropped85 avatar
bodydropped85
por 15 when your done, wont ever rust.
