front bags
front bags
N
nvrhapy
i got a 92 dak and started baggin the front today i got the passenger side tore apart and i got some full size chevy cups, i see the lower cup will drop in with some grinding but how exactly do you do the upper cup? also is there any tips or tricks need to know, i also have 2500 bags for the front i was going to drill out the cups to work with them is this ok? thanks
N
nvrhapy
the upper cup slips in fine right now and i'm aware of the trimming but how do you guys mount the upper cup ?
MF
Master Fabber
1. You can weld a nut to the cup then thread a piece of all thread up and then put a nut on top. 2. Ive never done this but Ive heard of the cups getting tacked in place. This would making changing a bag pretty difficult.
N
nvrhapy
so you can just set the upper cup in there without bolting or welding it???? wouldn't there be alot of shifting around???
Sickota's avatar
Sickota
i had mine floating for awhile but when you lay out to drag they rattle pretty bad so that is why i did what master fabber suggested for you to do.
bdroppeddak's avatar
bdroppeddak
ive done a bunch of them with no problems, just let it ride....... if they are loose when you lay the truck out, you are doing something wrong.......
downplz
I agree with this guy, my uppers are floating and never had a problem.
if yours are making noise sounds like its over bagged in the front to be and when it airs out the cups sink a bit out of the pocket and the cup rattles
