byc....control arms
11 following
louis_curl@yahoo.com's avatar
byc....control arms
societyoutkast's avatar
societyoutkast
has anybody had any problems with the control arms built by barn yard customs cause i am with the upppers real bad flexin at the welds and where it rounds for the ball joint..i can twist it with my hand...i'm just gonna put my truck back to static anybody want a bag set up for a grand plus shipping
societyoutkast
anybody are they even open anymore cause i cant get ahold of them
Gump1986
no, mike white is no longer in business
societyoutkast
that sux well i'm sellin the set up then i'm goin to a static and start workin on my bagged dually try to get it ready for midnight fantasies..i wanna atleast have it drag ready by then..lol
bodydropped85's avatar
bodydropped85
just put your stock upppers back on for now...
corey0814's avatar
corey0814
i ground down the welds at the plate & re welded them just to be safe because of all the people the had them bend. mine seemed fine, but i didn't want to take the chance. i posted all about them for someone else in the toyota forum. here's the link http://www.streetsourcemag.com/forum/topic.aspx?method=reply&topic_id=90048&forum_id=20&forum_title=&M=True&S=True
good luck.
BB
bill brasky
give me details on the bag setup
balcar's avatar
balcar
I've installed a few sets with no problems. (so far at least) If the weld is flexing, wouldn't it break pretty quick? Got a pic of what you are talking about?
no1lowr's avatar
no1lowr
brasky dont buy used parts. i will take care of you for under a grand just to make sure you dont get used shit. not a great idea. pussy ass mofucka
unusualfabrication's avatar
unusualfabrication
I recently fixed a pair of uppers from BYC, they were off an S-10. The ball joint plate was butt welded inbetween the two tubes which isn't very strong. It cracked the ball joint plate through the bolt holes because it was flexing so much. Luckily nobody was hurt because the customer was driving his truck when the arm broke. I put them on a jig and built new ball joint plates and sleeved them into the tubes a few inches for strengh. He hasn't had a problem with them since.
s10
last post by baha +1y
