Toyota Trucks \  question about stock spindles
Toyota Trucks Make Specific
views 827
replies 10
following 6
smallsyota   +1y
i have an 87 toyota pick-up and i have been looking around to see if swaping my spindles fros side to side will give me 2" lower up front...i was also whondering what brake booster i could use, cause my tire rubs
corey0814   +1y
you kinda lost me there; do you mean putting the left one on the right side & so on? if so then no it won't work, but if you're talking about putting them on upside down, i doubt that would work either.
here's a link to some pretty cheap belltech 2" drop spindles...
http://www.performancecenter.com/product/Lift+Kits/Spindles/0/4/0/Toyota/1988/Pickup/2WD?brandname=Belltech
good luck...
smallsyota   +1y
yeah im talking about just takeing the left one and put it upside down on the right side i have been told my many peolpe that it will work because the balls are the same size but what booster should i go to or how to move my one now?
TwistedMinis   +1y
The balljoint is a different size from top to bottom.
And a spindle swap will not work. Theres only a few vehicles out there that this works on, because of the simplistic spindle design. Mostly 50s cars that use a spindle thats nearly identical from side to side, and had drums.
Get a booster from a 79-83 Toyotoa 2WD truck. They are 8" diameter and will bolt in place.
smallsyota   +1y
cool thanks seth
m_i_zombie   +1y
Seth, this topic remind you of anything over at yotascene???
TwistedMinis   +1y
Phatboi. I was sure I had him convinced. I didn't think he'd do it though.
m_i_zombie   +1y
LOL, I really thought he was going to at one time. It would have been funny if had done it.
BioMax   +1y
Man, I could only imagine the steering issues that you would have if you were to build some custom arms that would accomodate upside down spindles. I think you would need monstertruck level steering dampeners. And I'm not even going into the camber issues you would end up with...
Severed701   +1y
my toyota lays out on a 225/30 20 with stock spindles and control arms..
