overspray
13 following
rickeystaton@rocketmail.com's avatar
overspray
laydout2004's avatar
laydout2004
whats the best stuff to use to get overspray off of new chrome wheels
BS
beyond static
Depending on the type of overspray you can try a few things. I just got done dealing with it on 1 of my wheels. Claybar didnt do a thing because mine were bad, but if they're not too bad, I'd try that first. Lacquer thinner didnt do much, so I hit it with some 000 steel wool. Worked great, and didnt scratch them.
cruisinlowS10
neverdull and some elbow grease is another option to try
BggdNBdyDrppdJunk's avatar
BggdNBdyDrppdJunk
try blech white, if its not too bad that might work, spray it on the dry wheel, let it sit then rub it out and hose em down, good luck bud
laydout2004
with the steel wool would you want to keep it wet while scrubing
Pa Pa Dragger's avatar
Pa Pa Dragger
If it's a light mist, Acetone should do it. Use a soft rag and soak the wheel with it a couple time to soften it up then work it in. One thing, Acetone will not harm the finsh of the wheel but steel wool will scratch them. I would try Acetone or Lacquer thinner before any type of abrasive.
asphalt is evil's avatar
asphalt is evil
try some buffing compound that gets it off paint easy
974door's avatar
974door
I used clay magic and soapy water
MashNSwitches's avatar
MashNSwitches
clay bar
bodydropped85's avatar
bodydropped85
id scrub it hard w/ virgin thinner or acetoen like they said. a clay bar should work to.
