metal glaze?
miashrnnd@bellsouth.net's avatar
metal glaze?
yasmany454ss's avatar
yasmany454ss
i im shaving some stuff on my truck the metal work is alsmost perfect should i put metal glaze filler sand it doing and then rage gold or straight to rage gold?
BS
beyond static
straight to rage gold. Use metal glaze ton top of the rage gold
yasmany454ss
wait let me get these clear im a little confused now.. metal glaze or metal to metal i dont know how you call it. is not like a fiberglass filler?
LAYNRKR's avatar
LAYNRKR
I'm a little confused also, I cant understand what the hell your asking. Use the Rage first, then use the glaze to fill the pinholes and imperfections. Use so damn punctuation next time.
sectioned88's avatar
sectioned88
I would use Rage Gold to get the bulk of the low, if you would even need the metal glaze you could use it for pinholes and minor lowspots. But you said it's pretty straight now so it's tough to say if you would even need it. Good thing to do is just get it roughed in as good as you can, then go ahead and build a few thick coats of primer and block it out to see what you have. That's how I would do it.
gravity5's avatar
gravity5
I would do the base of it with RAGE EXTREME, its a lot easier than the gold to sand...then glaze the imperfections out and use a 2k high build primer then a primer sealer over that.
treylos's avatar
treylos
well if your metal work is good as you say then you dont even need bondo just glaze it and block and prime..
