tail lights wont burn
cadillacstyle_98@msn.com's avatar
locaddy's avatar
locaddy
My girl's dad has a 97 4wd hardbody and he called me last night saying the tail lights and tag lights wont burn. All front lamps work, the brake lights and signals still work in the rear when activated but the tails and tag lamps will not. He says he has power to the sockets and all the fuses he checked were ok. Any help would be super because I have no idea what to look for. thanks.
SCINFERNL
Have you checked for electrical continuity at the plug end?
locaddy's avatar
locaddy
No I havent been there yet, gonna look at it when i get off work. Was hopin to get a few ideas on what to check. Thanks
lowdyme's avatar
lowdyme
i would check for power on the bulb side of the socket if it has power there then it needs some bulbs
BggdNBdyDrppdJunk's avatar
BggdNBdyDrppdJunk
make sure the bulbs are making a connection to the socket too, ive had loose bulbs that did that
bodydropped85's avatar
bodydropped85
i would check the ground.
ven's avatar
ven
The Blinker/Headlamp switch sometimes goes bad and will lose the running lights.
