Body work and Paint \  wet sanding primer?
wet sanding primer?
Body work and Paint Q & A
views 195
replies 7
following 5
bigjon   +1y
can you do it, is it the proper way or do you just have to struggle though blocking primer. this is my first time I need help.
bigjon   +1y
sorry impatient?
dragggn   +1y
yea you can wet sand (wet block sand too) primer..
just make sure you lt 'er dry befor recoating with any thing.
bigjon   +1y
if for some reason i got into the filler will that hurt anyting?
gravity5   +1y
A little bit will dry out...but don't keep wetsanding once you break thru...
bigjon   +1y
thanks,going to do it now
bodydropped85   +1y
yup add more primer then do it again.
sickdime94   +1y
before primer is applied hit it with the heat gun a little to dry out moisture,don't bake it though because it will blister the filler
