2600 ticking
2600 ticking
mets3000
I have a major tick in the engine when I start it up. After it gets warm it seems to go away but will go in and out while driving. I pulled the oil filler cap and I can feel air pushing out of the engine. Any help? I can't afford to have this thing crap on me.
layed521's avatar
layed521
Is your oil full? When mine ticks worse than normal its low about 1.5-2 quarts. How major is major?
2600air
Ive had three 2600's and they have all ticked. The one i'am currently drivin is a fresh rebuild motor an it also ticks. What i have found that helps is a quart of lucas oil stabilizer everytime you change the oil. Or chng to a heavier weight oil.
impulse's avatar
impulse
Probably your lifters... pretty common i think.
scrpnmazda's avatar
scrpnmazda
yeah mine does it too. its not bad but i can hear it tick every once in a while. my 92 2600i only has 145,000 on it.
dssur's avatar
dssur
HLA's, very common. I usually throw a quart of atf in the engine (in place of 1 quart of oil) and drive it a few thousand miles, then change the oil. The detergent in the atf really cleans the engine and emulsifies the varnish buildup, which is usually why lifters stick.
You can do the same thing with seafoam, or any other kerosene oil thinner, but its dangerous to drive on thin oil and you may dislodge large glops and plug your oiling system. I prefer the atf. And before yo worry about it, atf is just super concentrated detergent motor oil.
