Air Ride Suspensions \  Build me a solid Hydraulic setup!
Air Ride Suspensions Q & A
views 914
replies 13
following 13
ShavedClean96Accord   +1y
So, I'm thinking about trying juice for once. It's going to be on a 96 accord, and I'm really only interested in F/B action for right now.
I know I want accumulators for the ride, and I was thinking of 3 batteries...
Other than that, I was kinda hopeing to keep it in the $1000-1500 price range. If it's a little above, or a little below, close enough.
Details are a must, and it MUST be quality, as this will be my daily.
Thanks ahead of time!
SUBLOW   +1y
Its going to cost $1000-$1500 just for the plain jane pump setup, add accumulators and your looking at more, they're expensive..
laidout94toy   +1y
I spent 1300 just on my pro hopper setup.
You can get the basic pro hopper set up for around $800.
Dont forget about batteries and springs/or accumulators.
AON-4PumpedCL   +1y
When it comes to hydraulics, you get what you pay for. Not the time to take the cheap route.
roboblazer   +1y
Call Pro hopper!!!!
818-901-6100
detached   +1y
DO NOT USE REVERSE FLOW CYLINDERS. all i had was problems with those on two diffrent vehicles. get some triple seals and make them work. since your just wanting front to back a single pump could work
suckafree   +1y
I highly suggest these strut swivel cups from cce....things are bad ass!
http://www.coolcars.org/cce/strutcomp.htm
94juicednissan   +1y
check into cce they have all chrome setups in a complete deal minus battery's, plus accumalators is gonna run you 99 a piece!
coolcars.org
Maybe I should have mentioned that I already have 4 Stinger batteries left over from an audio insall, so batteries will not be an issue.
And I am aware that you don't want to go cheap. I am trying to keep some kind of budget, but if I go over it, then so be it!
