adhesive
onclemafia@aol.com's avatar
adhesive
BggdNBdyDrppdJunk's avatar
BggdNBdyDrppdJunk
will the adhesive given with cab emblems(aluminum ones) hold the aluminum decal to a billet grille? or will it fall off after a while? if it wont hold whats a good adhesive to use for aluminum?
corey0814's avatar
corey0814
if it's the type of emblems i'm thinking of...it will hold on, but not forever. that is, if it's the bar type billet (as in the insert or phantom type) only because of the spaces in between the bars for dirt & dust to get into. i don't know what you should use, but if you check it regularly, whenever it starts to feel slightly loose, just pull it off & use the 3M double sided tape (auto grade available at your local body shop supplier) & replace it over & over...
good luck
BggdNBdyDrppdJunk
thats what i figured, thanks for the help dude
bodydropped85's avatar
bodydropped85
it should just make sure the grill is clean b4 u put iton.
