front won't lift
12 following
cmsewell1@verizon.net's avatar
front won't lift
22dragn's avatar
22dragn
my front bags won't lift i hit the switch and nothing. the rear lift fine. i checked the line and the tanks and no leaks, could the valves be bad? the wiring is still fine not sure what else to check
MD
mr donut
if the valves are not clicking check your ground wire.
BB
bill brasky
When you hit the switch do they click like there is power there?
Have you pulled them off and taken them apart to see if there is any trash?
sinwagon
Does you tank have enough air in it? Sounds like you aren't letting it build enough pressure to lift the front. It takes 10 times the air pressure to lift the front than the back.
whynotfab's avatar
whynotfab
Yea, it sounds like not enough pressure, or a bad ground/loose connection.. Check over everything I'm sure you'll find the problem.. do the front valves click?
dirkbelt's avatar
dirkbelt
sounds like the valves arent working!!!!!!!!
22dragn's avatar
22dragn
the valves click and now i think my compressor might be going bad! it runs for like 10 min and it still not full. it's a air zenith with the pressure switch set to 185psi and after 10 min it only fills up to 80psi. the compressor is not even 6 months old.
Brill's avatar
Brill
If its an AZ, theres your problem.. mine has crapped out on me twice, AZ replaced it once.. then I had to rebuilt it.. and it only lasted a few months inbetween messups..
Scrap the AZ and go engine driven =)
MD
mr donut
i guess that is why they sell the rebuild kits. i have never had a problem personaly with viair comp.
keele's avatar
keele
Sounds like the compressor is your problem. 80 PSI isn't gonna get you too far lifting your front if any in an F150
s10
last post by baha +1y
