1994 s-10 pick up
1994 s-10 pick up
Q
quinn625
i check the fuse,but the brake lights wont work,i check the bulbs.is it the brake switch on the pedal.
LowPlainsDrifter
Could be the brake switch on the upper side of the pedal. Check the harness in the very back around the frame, I think there could be a ground there, maybe.
Texmextukin's avatar
Texmextukin
Yea, I would check the switch. But also be sure you have the grounds down. There are actually two. One on the input side of the harness for the tail-lights, then one on the wires that run up to the harness itself. They're both held on with a self-tapping bolt on the inside of the frame
blazedout84's avatar
blazedout84
ya first thing id do is get a test light and go from there
