Mazda Trucks \  narrowed rear- how much should it cost??
Mazda Trucks Make Specific
views 278
replies 14
following 10
slammedstroller   +1y
so I am almost done with my body dropand I know the rear clearance problem has to be delt with.. so how much should it cost to get it narrowed? I cant swap to older style rearend because it is 6 lug and I am already converted to 5
LAYNRKR   +1y
moser charges 110 for an axle respline, and 110 for your actual housing.
FLYINLO   +1y
Swap in an older Toyota rearend or Ranger rearend.
slammedstroller   +1y
anyone know how much narrower the toyota or ranger is?
bdroppeddak   +1y
the pre 84 is 3" narrower.... ryan have you had moser do import truck axles before? i was curious if they could respline them or just made new axles... the new ones would run you about 265 bucks shipped with new studs.....
oneroom42   +1y
i just pulled my rear out and took it to a machine shop and after a month they told me they couldnt do it because of the bearings and shims. i cant understand it. is it possible to shorten 1 3/8" on each side or not? if so where should i go?
TwistedMinis   +1y
Get an axle from an early Toyota. $100 at the junkyard. 73-78 is 53" wide. 79-83 is 55" wide. 84-88 I think is 56" or 56.5" wide.
Cris, Moser will do all new axles. I know of a 10" narowed axle in a Taco with brand new axles that are like a foot long. Lol.
bagdb2200   +1y
56" wide, '79-95 2wd Trucks - 5 Lug
This is info I've seen but I don't think it's for the 79-95, maybe 84-95...
TwistedMinis   +1y
79-83 is 55" wide, I'm 100% sure.
slammedstroller   +1y
how wide is the stock mazda one and where are you measuring to?
