Audio/Video \  RCA wires???????
RCA wires???????
Audio/Video Q & A
views 215
replies 7
following 7
thehammer001   +1y
Edited: 5/16/2007 12:52:19 PM by thehammer
So does anyone make RCA wires that would plug into my stereo sub output and then would be able to be plugged into two amp inputs? So esentially a one into two.
something like ------====== like that if that helps. And when i say one into two i am talking about a left right into a left right and a left right.
ShakinPlates   +1y
NONE OF YOUR AMPS HAVE A "PASS-THRU" RCA OUTPUT?
LOWEST1   +1y
You can get "Y" adapters
KentuckyKillerKlown   +1y
The Y adapters are going to be your best bet. That is what is used for my two sub amps.
thehammer001   +1y
The only amp I have that has a pass-thru set up is my 4 channel MTX TC4004. The other two (MTX TC4001) only have inputs. Does streetwires or someone make those "Y" adapters? By the way I really appreciate the replies. Thanks
bodydropped85   +1y
yea they should, if not radio shack will have some. i do believe there called splitters.
granth   +1y
James is right, they are called splitters. Although I wouldn't go to your local Radio Shack for your car audio needs, unless you are building a crossover or something like that.
Look into Knu Konceptz wires. Very affordable and VERY high quality. That or stinger....or kicker. Going from least expensive to most expensive, all on par with each other.
no1lowr   +1y
kikcer makes a nice set of y cables
