Mazda Trucks \  TURBO CHARGING A B2000
Mazda Trucks Make Specific
views 87
replies 3
Sexyboygigalo   +1y
Does it have to be fuel injected?Or can i just run all the lines and have my turbo timer and boost controller and air fuel ratio gauge set up right??please let me kno asap
LOWEST1   +1y
You can run a carb, been done on B-series lots of times. I personally would run Fuel injection.
Kyrasis6   +1y
There are a couple ways to do it, probably the easiest is to build an air tight box around the entire carb that the turbo blows into. Then you would just have to rejet the carb for the turbo.
The box is needed to stop the extra pressure from blowing out seals and pushing fuel through the throttle shaft openings and stuff.
custom92   +1y
i know you can run a ford probe gt turbo on the b series but i belive that it has to be fuel injected but good luck that sounds bad ass..
