What size heim joints and where you get em from?
I
Idragit
I'm finishing up my 4 link and I need to do the upper link. What size heim joints is everyone using? WHere you getting them from? Is everyone using tubing with welded in bungs or solid steel tapped? thanks
I
Idragit
thanks awesome site...What size should I be using?
TwistedMinis's avatar
TwistedMinis
I would use 1/2" or 5/8" of you get the chromoly ones. If I was doing a wishbone, I'd make the singe joint a 3/4" heim and put high misalignments on it to make it look cool.
I
Idragit
high misalignments?
TwistedMinis
Look in the miscalignment spacer section.
I
Idragit
What is that? I see it..and it looks cool..but what is the difference in that and a regular bung?
TwistedMinis
Did you look at this page? http://ballisticfabrication.3dcartstores.com/High-Misalignment-_c_81-1.html
Its not a bung at all, it lets the heim pivot farther. There is an animated image on that page that shows how they work.
I would use somethign like that if it were the only source for pivot on that plain of the axle.
I
Idragit
I see now...that is awesome...I'll definately be ordering those monday..thanks
s10
last post by baha +1y
