bagging 99 4dr tahoe questions????
11 following
navigangsta@gmail.com's avatar
NaviGangsta's avatar
NaviGangsta
First, any sites devoted to these?
second, how low will it sit bagged on 20's (255.35.20)without tubbing the back? I will shove the bigest notch under it i can without cutting into the interior area.
is there enought room under there to shove a forward 4link? I prefer a wishbone setup but ill compromise to a parallel.
rockstar-c10's avatar
rockstar-c10
It will almost lay frame on 20s with an under the floor notch. As far as a 4 link you will have to relocate the gas tank, you would be better off doing a two link with a panhard bar or watts link.
NaviGangsta
I would NEVER do a crappy 2link, sorry.
Ill prolly go with a parallel 4link
NaviGangsta
anyone?
sittinonbagz's avatar
sittinonbagz
better for you to run a 2 link if so you dont have to move the gas tank and it will sit low but it u really wanna make it tuck put the tubs
kotalaynframe's avatar
kotalaynframe
on my girls tahoe lays frame with 20s without cutting any thing on a 2 link the only thing i hate is that you cant drag its going to get cut up as soon as i finish my other projects
tcsxtremeison22s's avatar
tcsxtremeison22s
how about laying the rear on 24's? i have a 99 4door but its 4wd... is it possible to lay 24's in the rear without hackin up interior??? any difference between 2wd and 4wd with the rear suspension??? i don't expect the front to get anywhere near layin out on 24s, but i've been curious if there's a way to lay 24's in the rear without cuttin up all the interior... im running 305/35/24's...
kotalaynframe
my girls tahoe has my 24s on for right now and the frame is bout a foot of the ground but the 4wd has a different frame so i dont know
purplekush's avatar
purplekush
why not just go with 18's and lay out with no cutting of the floor
JayMack75's avatar
JayMack75
I got a suburban, inside is tubbed but you can hardly tell.
Click here to see it
