i set up the back of my truck with bags over axel set up for 22s. but now im riding on 18s and i get shitty lift. what can i use to space it out till i get 22s....
TwistedMinis
Some 5" tubing, cut to the right size, with a plate on each side, with some long ass bolts. You you could be trick about it and make it bolt to the bag, and make a plate for the bottom that bolts to the lower bracket that still allows you to access the bolts in the bottom of the bag.
Or just buy a bunch of lower bag brackets.
time1
On my old yota we set it up for bigger wheels in the back but i was rolling 18's. I had a spacer under the bag the 3/4" tall. It was made from a piece of pipe with the same diameter as the bag plate. Worked good for years without any problems.
