Lowering 88 Isuzu pup
TwinBallersCasper@hotmail.com's avatar
19BaggedMitsu92's avatar
19BaggedMitsu92
whats the best way to lowere a 88 isuzu pickup without baggin it?
CalvinRollin720
get a set of lowering blocks at almost any auto part store then lower your torsion bars there right underneath your front seats on the bottom of your truck dont go to low you'll bottom out alot had my 720 slammed rode like a wagon but oh well...
19BaggedMitsu92
would drop spindles or anything help out at all, that way i wont have to lower my torsion bars as much?
sponge splawn's avatar
sponge splawn
What I did the first time I lowered my Spacecab was ad 3" blocks to the rear after removing the overload leaf, then instead of turning the torsion bars down, mark their thread location and then loosen the bolts and hammer the fronts of the torsion bars out of the splins and respline them about 3 or 4 notches. Pound them back in and then tighten the bolts back up to the same position on the threads. You may need to cut or pull the bump stops depending on how low you go. The truck should ride the same, only lower. Good luck
mmrcustoms's avatar
mmrcustoms
yes the guy abouve is right pull them out and and adjust them and put them back in it will look badass
19BaggedMitsu92
u got me lost to tell u the truth. ive never had a torsion bar truck. give me some more details
bagged91mazda's avatar
bagged91mazda
take out the torsion bars.You will have to take the bolt all the way out then get a hammer and bang them out.U will have to jack up your truck to do it.But once they are out turn them down were the bolt goes throw will be facing towards the ground not strait down how i do it is put the bolt in the torsion bar and put them back in where the bolt is just starting then u can crank them up and u wont rip out your bars that way.U might have to take out the bump stop up front so it will ride good and put in a shorter shock.Also in the back put a 3 inch block in the back and take out all the leafs but the main one called a mono leaf it will sit way low and ride good u will also have to get shrter shocks for the back.I would run air shocks on the back so u can raise it upo alittle for a better ride. Hope that helps u
19BaggedMitsu92
it helps a lil bit, ill see if i can tell what ur talkin about.
Related Discussions in Isuzu
