sfbd newer rams
sfbd newer rams
spitfire062
sfbd on the 02 to 05 dodge ram do you have to end up cuttin the floor for the tranny? thats next on my list
alftuckin22s
How far is your B.D? also i'm assuming you z'd the frame if you did then answer is a definate yes!! I'm goin to the doors and I'm gonna raise the tranny tunnel a few inches along with some room for drive shaft. check out the srt26 post whoever did that one almost has a step by step minus the b.d but its pretty damn close. It will give you a general Idea of what has to be done. hope that helps ya out!!
spitfire062
i havent started it yet just tryin to get an idea of just what im gettin my self into. idk if im gonna go to the doors or not its my daily so i gotta watch what i do
thacru78's avatar
thacru78
I'm going to the doors on mine and i had to raise the tunnel about 2 inches. I ended up dropping the engine down as far as it would go. I have about 1/2 clearance on the oil pan plug, and the tranny pan. So I would think you would on a SFBD to the rockers. You can modify the motor mounts on the frame to drop the motor down to give you more clearance.
thacru78's avatar
thacru78
Mine will be a Daily Door Dragger. I'm thinking about puttin some training wheels on for non-show driving. But probably not. The whole needing to be air up to open the doors will start to get old. But i'm pretty sure I got that figured out using my remote and my AVS switch box.
