Chevy/GMC Trucks \  00 silverado reAr end
views 223
replies 10
following 6
choppedcivic98   +1y
When i turn to the right my rear end pops loud as hell????
FullSizeRST   +1y
drain your rear diff fluid if you got peices comming out that should tell you something my work truck does that but because it locks really easy for some reason
choppedcivic98   +1y
I think it might be my axle bearings???
FullSizeRST   +1y
does it only pop or does it wine or sqweel anny??
choppedcivic98   +1y
a slight squeel but i jacked up the rear end and the passanger side wheel has alot of play in it!
FullSizeRST   +1y
might be ur bearings id get it checked out ....do you have anny grease or oil on the inside of ur rim?
choppedcivic98   +1y
nope!!!!
Wakeboard03S10   +1y
this same thing happend on my buddys suburban. iam not exactly sure on what went out but something did and he found it was cheaper to buy a used one and have it installed then it was to have whatever was wrong replaced or repaired.
phat phabrikationz   +1y
Ive heard its a common thing with the 99-up silverados... The rearends will just do that...
Had a buddy take his to the dealership, thats what they told him.
choppedcivic98   +1y
damn, thanks for the info, what sucks is i need a truck to pull a trialer daily!!!
