96 tacoma help
stkflrd73@yahoo.com's avatar
96 tacoma help
stkflrd73's avatar
stkflrd73
just got the truck back togather now i have no power to my fuel pump and when i bypass it and run a hot to the pump, still nothing..and ideas?what powers the pump a fuse or relay
thanks for any help!!!!
stkflrd73's avatar
stkflrd73
its not getting spark
anyone ever had this problem
the truck was running before the suspension work...
maybe a ground?
any help???
Severed701's avatar
Severed701
if you just did susp work you probably removed the wheel wells and the igniter on the pass side had to be moved..that needs to be mounted solid to a good ground...thats the first thing i would check into
stkflrd73's avatar
stkflrd73
ill look at it ... someone else hacked the truck up before i got to it what does this look like ?
sorry im an idiot about toyota or most new truck wiring
chumpchange's avatar
chumpchange
little square silver box with two monts 3inches square and has a wiring harness going to it ill bet thats you problem same problem i had.
stkflrd73's avatar
stkflrd73
did you just plug it in and know it works?
thanks
chumpchange
it needs to be bolted to something solid. it grounds through the mount and te truck willnot run without it.
